Gateway MD2614u Fan Replacement
    1. Gateway MD2614u Fan Replacement, Back Cover: step 1, image 1 of 1
      • Place the laptop so the back cover is facing up.
      Ask FixBot
    2. Gateway MD2614u Fan Replacement: step 2, image 1 of 1
      • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
      Ask FixBot
    3. Gateway MD2614u Fan Replacement: step 3, image 1 of 1
      • Lift off the cover.
      Ask FixBot
    1. Gateway MD2614u Fan Replacement, Fan: step 4, image 1 of 1
      • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
      • Pull the plastic part of the cable, not the wires, so that the plug does not break.
      Ask FixBot
    2. Gateway MD2614u Fan Replacement: step 5, image 1 of 1
      • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
      Ask FixBot
    3. Gateway MD2614u Fan Replacement: step 6, image 1 of 1
      • The fan is permanently attached to the silver heat sink next to the RAM.
      • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
      • Take out the screws in the numerical order shown on the heat sink.
      Ask FixBot
    4. Gateway MD2614u Fan Replacement: step 7, image 1 of 1
      • Pull the fan and heat sink toward you at a 20 degree angle upward.
      Ask FixBot
2 other people completed this guide.
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 97
All Time: 5,589
