Gateway MD2614u Battery Replacement
    1. Gateway MD2614u Battery Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
      Ask FixBot
    2. Gateway MD2614u Battery Replacement: step 2, image 1 of 1
      • Slide and hold the battery release lock to the left.
      Ask FixBot
    3. Gateway MD2614u Battery Replacement: step 3, image 1 of 1
      • Pull the battery away from the laptop.
      Ask FixBot
    4. Gateway MD2614u Battery Replacement: step 4, image 1 of 1
      • Insert the new battery into the slot.
      Ask FixBot
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 102
All Time: 4,514
