Up to 20% off select tools
Gateway MA7 Hard Drive Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
59
All Time:
2,116
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the Hard Drive in your Gateway MA7 laptop. The hard drive for your laptop stores all of your computer's information. If your hard drive is corrupt it will need to be replaced in order for it to turn on. You can also replace the hard drive if you want to have more storage.
    1. Gateway MA7 Hard Drive  Replacement, Hard Drive: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged and off before removing the battery.
      • To unlock the battery slide both switches marked in the picture to the unlocked position, the one on the left marked in pink will need to be held while you remove the battery.
      Ask FixBot
    2. Gateway MA7 Hard Drive  Replacement: step 2, image 1 of 3 Gateway MA7 Hard Drive  Replacement: step 2, image 2 of 3 Gateway MA7 Hard Drive  Replacement: step 2, image 3 of 3
      • Remove the two 6 mm Phillips #0 screws from the back of the hard drive cover.
      Ask FixBot
    3. Gateway MA7 Hard Drive  Replacement: step 3, image 1 of 3 Gateway MA7 Hard Drive  Replacement: step 3, image 2 of 3 Gateway MA7 Hard Drive  Replacement: step 3, image 3 of 3
      • Press down firmly on the hard drive and pull leftwards.
      Ask FixBot
    4. Gateway MA7 Hard Drive  Replacement: step 4, image 1 of 3 Gateway MA7 Hard Drive  Replacement: step 4, image 2 of 3 Gateway MA7 Hard Drive  Replacement: step 4, image 3 of 3
      • Remove two 4 mm Phillips #0 screws from the plastic hard drive cover.
      • Lift the hard drive up from the plastic cover.
      Ask FixBot
Author
with
De’Andra Clarke
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 59
All Time: 2,116
