Gateway MA7 CD/DVD Drive Replacement
    1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Push the locking tab over to the right away from the battery to unlock it from the laptop.
      • Hold the additional locking tab to the left while puling out the battery.
      Ask FixBot
    2. Gateway MA7 CD/DVD Drive Replacement: step 2, image 1 of 2 Gateway MA7 CD/DVD Drive Replacement: step 2, image 2 of 2
      • Remove the following screws securing the plastic panel from the bottom of the laptop:
      • Remove the seven 6 mm screws with a Phillips #0 screwdriver
      Ask FixBot
    3. Gateway MA7 CD/DVD Drive Replacement: step 3, image 1 of 3 Gateway MA7 CD/DVD Drive Replacement: step 3, image 2 of 3 Gateway MA7 CD/DVD Drive Replacement: step 3, image 3 of 3
      • Pull upwards on the top of the plastic panel to remove it.
      • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
      Ask FixBot
    4. Gateway MA7 CD/DVD Drive Replacement: step 4, image 1 of 2 Gateway MA7 CD/DVD Drive Replacement: step 4, image 2 of 2
      • Remove the following screws holding the DVD/CD drive in place:
      • One 6 mm Phillips #0
      Ask FixBot
    5. Gateway MA7 CD/DVD Drive Replacement: step 5, image 1 of 1
      • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
      • While pressing down, push the metal latch out away from the laptop.
      Ask FixBot
    6. Gateway MA7 CD/DVD Drive Replacement: step 6, image 1 of 3 Gateway MA7 CD/DVD Drive Replacement: step 6, image 2 of 3 Gateway MA7 CD/DVD Drive Replacement: step 6, image 3 of 3
      • Once the drive has been pried out, you can pull the CD drive out.
      Ask FixBot
Tim Rose
392 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 60
All Time: 984
