Gateway MA6 Laptop Wireless Card Replacement
    1. Gateway MA6 Laptop Wireless Card Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
      Ask FixBot
    2. Gateway MA6 Laptop Wireless Card Replacement: step 2, image 1 of 3 Gateway MA6 Laptop Wireless Card Replacement: step 2, image 2 of 3 Gateway MA6 Laptop Wireless Card Replacement: step 2, image 3 of 3
      • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
      • Firmly pull the battery outwards and away from the laptop.
      Ask FixBot
    1. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
      • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
      • The screw will remain in the backplate.
      • Lift upwards on the back plate to remove it.
      Ask FixBot
    2. Gateway MA6 Laptop Wireless Card Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
      Ask FixBot
    3. Gateway MA6 Laptop Wireless Card Replacement: step 5, image 1 of 1
      • Remove the 2 mm Phillips #0 screw.
      • The card will lift itself up 30° after the screw has been removed.
      Ask FixBot
    4. Gateway MA6 Laptop Wireless Card Replacement: step 6, image 1 of 2 Gateway MA6 Laptop Wireless Card Replacement: step 6, image 2 of 2
      • Hold the WiFi card on both sides and pull outwards to remove it.
      Ask FixBot
Chris Naughton
727 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 101
All Time: 1,277
