Up to 20% off select tools
Gateway MA6 Laptop RAM Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
88
All Time:
1,881
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The RAM in this laptop can be accessed easily with very little disassembly. There are two slots that both accept PC2-5300S RAM.
    1. Gateway MA6 Laptop RAM Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
      Ask FixBot
    2. Gateway MA6 Laptop RAM Replacement: step 2, image 1 of 3 Gateway MA6 Laptop RAM Replacement: step 2, image 2 of 3 Gateway MA6 Laptop RAM Replacement: step 2, image 3 of 3
      • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
      • Firmly pull the battery outwards and away from the laptop.
      Ask FixBot
    1. Gateway MA6 Laptop RAM Replacement, RAM: step 3, image 1 of 2 Gateway MA6 Laptop RAM Replacement, RAM: step 3, image 2 of 2
      • Remove the seven 6 mm Phillips #0 screws from the back of the case.
      • Leave all the screws in the back plate and so you don't lose them.
      Ask FixBot
    2. Gateway MA6 Laptop RAM Replacement: step 4, image 1 of 2 Gateway MA6 Laptop RAM Replacement: step 4, image 2 of 2
      • Pull upwards on the top of the back cover to remove it.
      Ask FixBot
    3. Gateway MA6 Laptop RAM Replacement: step 5, image 1 of 3 Gateway MA6 Laptop RAM Replacement: step 5, image 2 of 3 Gateway MA6 Laptop RAM Replacement: step 5, image 3 of 3
      • Pull outwards on the silver metal pins to release the upper RAM module.
      • The module will automatically lift up 30° after it has been released.
      Ask FixBot
    4. Gateway MA6 Laptop RAM Replacement: step 6, image 1 of 2 Gateway MA6 Laptop RAM Replacement: step 6, image 2 of 2
      • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
      • Repeat the same process for the lower RAM module.
      Ask FixBot
Author
with
Chris Naughton
727 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 88
All Time: 1,881
