Gateway MA6 Laptop Hard Drive Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
98
All Time:
2,599
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Your laptop hard drive stores all of your files, as well as your computer's operating system. A corrupt hard drive will need to be replaced for your computer to power on and run. It is common to upgrade to a larger hard drive with more storage space.
Tools
    1. Gateway MA6 Laptop Hard Drive Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
      Ask FixBot
    2. Gateway MA6 Laptop Hard Drive Replacement: step 2, image 1 of 3 Gateway MA6 Laptop Hard Drive Replacement: step 2, image 2 of 3 Gateway MA6 Laptop Hard Drive Replacement: step 2, image 3 of 3
      • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
      • Firmly pull the battery outwards and away from the laptop.
      Ask FixBot
    1. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
      Ask FixBot
    2. Gateway MA6 Laptop Hard Drive Replacement: step 4, image 1 of 2 Gateway MA6 Laptop Hard Drive Replacement: step 4, image 2 of 2
      • Press thumb down firmly on the hard drive and pull outwards to the side.
      Ask FixBot
3 other people completed this guide.
Chris Naughton
727 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
132 Guides authored
1 Guide Comment
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 98
All Time: 2,599
