Gateway MA6 Laptop Cooling Assembly Replacement
    1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: step 1, image 1 of 2 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: step 1, image 2 of 2
      • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
      • Leave all the screws in the back plate and so you don't lose them.
      Ask FixBot
    2. Gateway MA6 Laptop Cooling Assembly Replacement: step 2, image 1 of 2 Gateway MA6 Laptop Cooling Assembly Replacement: step 2, image 2 of 2
      • Pull upwards on the top of the back cover to remove it.
      Ask FixBot
    3. Gateway MA6 Laptop Cooling Assembly Replacement: step 3, image 1 of 1
      • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
      Ask FixBot
    4. Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 1 of 3 Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 2 of 3 Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 3 of 3
      • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
      • Gently flip the cooling fan assembly upside-down on the computer surface.
      • Carefully grab the wire attached to the computer and pull away from the port.
      • The cooling fan is now safe for removal.
      Ask FixBot
    5. Gateway MA6 Laptop Cooling Assembly Replacement: step 5, image 1 of 1
      • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
      • If your unfamiliar with applying thermal paste How to Apply Thermal Paste
      Ask FixBot
2 other people completed this guide.
Chris Naughton
727 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 98
All Time: 1,443
