Gateway M-2626u Hard Drive Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
62
All Time:
720
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The replacement of the hard drive may be necessary if you experience crashes frequently or if there is data loss and file corruption. You can also upgrade the hard drive if you would like to have access to more storage or faster laptop in general, either way, try out this simple guide!
Tools
    1. Gateway M-2626u Hard Drive Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is not plugged in while removing the battery!
      • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
      Ask FixBot
    2. Gateway M-2626u Hard Drive Replacement: step 2, image 1 of 3 Gateway M-2626u Hard Drive Replacement: step 2, image 2 of 3 Gateway M-2626u Hard Drive Replacement: step 2, image 3 of 3
      • Push the switch to the right, toward the inside of the computer to dislodge the battery.
      • Finally, pull the battery outwards and away from the laptop as depicted in this image.
      Ask FixBot
    1. Gateway M-2626u Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Gateway M-2626u Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
      Ask FixBot
    2. Gateway M-2626u Hard Drive Replacement: step 4, image 1 of 1
      • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
      Ask FixBot
    3. Gateway M-2626u Hard Drive Replacement: step 5, image 1 of 3 Gateway M-2626u Hard Drive Replacement: step 5, image 2 of 3 Gateway M-2626u Hard Drive Replacement: step 5, image 3 of 3
      • Using your hands, carefully pull out the hard drive from its compartment.
      Ask FixBot
Femi
219 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 62
All Time: 720
