Up to 20% off select tools
Gateway Lt4004u Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
26
Past 30 Days:
98
All Time:
1,240
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a moderately difficult process. There aren't many steps, but make sure you follow the first steps closely to insert the card correctly.
    1. Gateway Lt4004u Keyboard Replacement, Battery: step 1, image 1 of 3 Gateway Lt4004u Keyboard Replacement, Battery: step 1, image 2 of 3 Gateway Lt4004u Keyboard Replacement, Battery: step 1, image 3 of 3
      • Place the laptop face down in front of you.
      • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
      • Pinch the switches and slide toward the edges of the computer to unlock.
      Ask FixBot
    2. Gateway Lt4004u Keyboard Replacement: step 2, image 1 of 2 Gateway Lt4004u Keyboard Replacement: step 2, image 2 of 2
      • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Gateway Lt4004u Keyboard Replacement, Keyboard: step 3, image 1 of 3 Gateway Lt4004u Keyboard Replacement, Keyboard: step 3, image 2 of 3 Gateway Lt4004u Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Open the laptop so that the screen and keyboard are facing you.
      • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
      Ask FixBot
    2. Gateway Lt4004u Keyboard Replacement: step 4, image 1 of 3 Gateway Lt4004u Keyboard Replacement: step 4, image 2 of 3 Gateway Lt4004u Keyboard Replacement: step 4, image 3 of 3
      • Use an opening pick to push each tab away from you.
      • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
      • A clicking sound is normal and no cause for alarm.
      Ask FixBot
    3. Gateway Lt4004u Keyboard Replacement: step 5, image 1 of 3 Gateway Lt4004u Keyboard Replacement: step 5, image 2 of 3 Gateway Lt4004u Keyboard Replacement: step 5, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
      • Carefully pry the keyboard from the main frame, starting at the top section.
      • Look at the intel sticker in this step and the next to orient your computer with the pictures.
      Ask FixBot
    4. Gateway Lt4004u Keyboard Replacement: step 6, image 1 of 2 Gateway Lt4004u Keyboard Replacement: step 6, image 2 of 2
      • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
      • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
      • The popping noise will not hurt the computer.
      • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
      Ask FixBot
Author
with
Carlisle Hiott
821 Reputation
7 Guides authored
Clemson, Team 6-5, Benson Spring 2016 Member of Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 98
All Time: 1,240
