Up to 20% off select tools
Gateway LT41P10u Monitor Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
94
All Time:
850
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This is the guide for complete removal of the Gateway LT41P10u monitor. When removing monitor handle with care to avoid possibly cracking the screen.
    1. Gateway LT41P10u Monitor Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down on a flat surface so you can see the battery.
      Ask FixBot
    2. Gateway LT41P10u Monitor Replacement: step 2, image 1 of 1
      • Pull the two marked tabs towards the outside of the computer to unlock them.
      Ask FixBot
    3. Gateway LT41P10u Monitor Replacement: step 3, image 1 of 1
      • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
      Ask FixBot
    1. Gateway LT41P10u Monitor Replacement, Monitor: step 4, image 1 of 2 Gateway LT41P10u Monitor Replacement, Monitor: step 4, image 2 of 2
      • Carefully use a spudger to separate the monitor from top panel.
      • Gently remove lower hooks from the hinges. (see second image)
      Ask FixBot
    2. Gateway LT41P10u Monitor Replacement: step 5, image 1 of 2 Gateway LT41P10u Monitor Replacement: step 5, image 2 of 2
      • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
      • The second image is how it should look once completely disconnected.
      Ask FixBot
To reinstall your device, follow these instructions in reverse order.
Author
with
Michael Smith
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 94
All Time: 850
