Up to 20% off select tools
Gateway LT41P10u Keyboard Replacement
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
101
All Time:
1,041
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This is a guide for the removal of the full keyboard from the Gateway LT41P10u laptop. If you want to re-use the keyboard you are taking out, be careful not to bend the keyboard as you are removing it, since it can bend easily if you use too much force removing it.
    1. Gateway LT41P10u Keyboard Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down on a flat surface so you can see the battery.
      Ask FixBot
    2. Gateway LT41P10u Keyboard Replacement: step 2, image 1 of 1
      • Pull the two marked tabs towards the outside of the computer to unlock them.
      Ask FixBot
    3. Gateway LT41P10u Keyboard Replacement: step 3, image 1 of 1
      • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
      Ask FixBot
    1. Gateway LT41P10u Keyboard Replacement, Keyboard: step 4, image 1 of 2 Gateway LT41P10u Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
      • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
      • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
      Ask FixBot
    2. Gateway LT41P10u Keyboard Replacement: step 5, image 1 of 1
      • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
      • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
      • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
      Ask FixBot
To reinstall your keyboard, follow these instructions in reverse order.
Author
with
Michael Smith
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 101
All Time: 1,041
