Up to 20% off select tools
Gateway LT4004u Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
22
Past 30 Days:
86
All Time:
1,278
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a moderately difficult process. The screen is an essential part of the computer and it is important to follow these steps with care to prevent unwanted damages to the device.
    1. Gateway LT4004u Screen Replacement, Screen: step 1, image 1 of 3 Gateway LT4004u Screen Replacement, Screen: step 1, image 2 of 3 Gateway LT4004u Screen Replacement, Screen: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Open the laptop so that the screen and keyboard are facing you.
      • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
      Ask FixBot
    2. Gateway LT4004u Screen Replacement: step 2, image 1 of 3 Gateway LT4004u Screen Replacement: step 2, image 2 of 3 Gateway LT4004u Screen Replacement: step 2, image 3 of 3
      • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
      Ask FixBot
    3. Gateway LT4004u Screen Replacement: step 3, image 1 of 3 Gateway LT4004u Screen Replacement: step 3, image 2 of 3 Gateway LT4004u Screen Replacement: step 3, image 3 of 3
      • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
      • Be prepared to hear cracking noises. These are expected.
      • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
      • Remove the screen casing.
      Ask FixBot
    4. Gateway LT4004u Screen Replacement: step 4, image 1 of 3 Gateway LT4004u Screen Replacement: step 4, image 2 of 3 Gateway LT4004u Screen Replacement: step 4, image 3 of 3
      • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
      • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
      Ask FixBot
    5. Gateway LT4004u Screen Replacement: step 5, image 1 of 3 Gateway LT4004u Screen Replacement: step 5, image 2 of 3 Gateway LT4004u Screen Replacement: step 5, image 3 of 3
      • Unplug the webcam connection from the top of the laptop screen backing.
      Ask FixBot
    6. Gateway LT4004u Screen Replacement: step 6, image 1 of 3 Gateway LT4004u Screen Replacement: step 6, image 2 of 3 Gateway LT4004u Screen Replacement: step 6, image 3 of 3
      • Flip the screen over so that it is lying on top of the keyboard.
      • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
      Ask FixBot
    7. Gateway LT4004u Screen Replacement: step 7, image 1 of 1
      • Remove the screen from the rest of the laptop.
      Ask FixBot
Author
with
Carlisle Hiott
821 Reputation
7 Guides authored
Clemson, Team 6-5, Benson Spring 2016 Member of Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 86
All Time: 1,278
