Gateway LT2514u Battery Replacement
    1. Gateway LT2514u Battery Replacement, Battery: step 1, image 1 of 2 Gateway LT2514u Battery Replacement, Battery: step 1, image 2 of 2
      • With the netbook's lid closed, flip it over and slide the latch on the upper left hand side of the netbook to the left.
      • You should see an orange indicator when the battery is unlocked.
      Ask FixBot
    2. Gateway LT2514u Battery Replacement: step 2, image 1 of 2 Gateway LT2514u Battery Replacement: step 2, image 2 of 2
      • In the upper right-hand corner of the netbook, slide and hold the switch to the right.
      • Use your other hand to slide out the battery.
      • If the release switch in the upper right-hand area is missing, you can still remove the battery by following Step 3. Otherwise, skip it.
      Ask FixBot
    3. Gateway LT2514u Battery Replacement: step 3, image 1 of 3 Gateway LT2514u Battery Replacement: step 3, image 2 of 3 Gateway LT2514u Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • If the release switch in the upper right-hand area is missing, insert a slender tool (we used tweezers) into the left side of the smaller hole.
      • Slide and hold the tweezers to the right and use your other hand to slide the battery out.
      Ask FixBot
Brian Garver
839 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Fall 2016 Member of USF Tampa, Team 3-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 96
All Time: 814
