Up to 20% off select tools
Gateway LT2104u RAM Replacement Guide
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
95
All Time:
923
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to safely remove and replace the RAM stick of a Gateway LT2104u.
    1. Gateway LT2104u RAM Replacement Guide, RAM: step 1, image 1 of 1
      • Locate the the "L" shaped cover on the back, lower right hand side the device. Using a Philips screwdriver, remove the screw holding it in.
      Ask FixBot
    2. Gateway LT2104u RAM Replacement Guide: step 2, image 1 of 2 Gateway LT2104u RAM Replacement Guide: step 2, image 2 of 2
      • Gently lift the cover until it detaches from the device.
      Ask FixBot
    3. Gateway LT2104u RAM Replacement Guide: step 3, image 1 of 2 Gateway LT2104u RAM Replacement Guide: step 3, image 2 of 2
      • Gently push the levers on each side of the stick of RAM away from each other until the RAM springs into a 45° angle.
      Ask FixBot
    4. Gateway LT2104u RAM Replacement Guide: step 4, image 1 of 1
      • Carefully remove the stick of RAM by pulling at the same 45° angle the RAM is currently at until it detaches from the device.
      Ask FixBot
    5. Gateway LT2104u RAM Replacement Guide: step 5, image 1 of 1
      • When inserting the new stick of ram, be sure to insert it at the same 45° angle that the old stick of ram was taken out at. Press the stick of RAM down until it clicks into place.
      Ask FixBot
Author
with
Chris Sullivan
234 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 95
All Time: 923
