Gateway KAV60 LT2016U Key Replacement
    1. Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 1 of 3 Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 2 of 3 Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 3 of 3
      • Unlock the tab located in the top left corner of the netbook.
      • The red tab indicated that the battery has been properly unlocked.
      • Remove the battery.
      • When working with electronics, it is always wise to remove the power source before taking the device apart.
      Ask FixBot
    1. Gateway KAV60 LT2016U Key Replacement, Key: step 2, image 1 of 2 Gateway KAV60 LT2016U Key Replacement, Key: step 2, image 2 of 2
      • Any key on the keyboard can be replaced.
      • Insert the plastic opening tool under the key to be replaced.
      Ask FixBot
    2. Gateway KAV60 LT2016U Key Replacement: step 3, image 1 of 1
      • The key is easily removed by applying force to the plastic opening tool until the key pops off.
      Ask FixBot
Lydia Benjock
1,255 Reputation
10 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 93
All Time: 1,234
