Gateway KAV60 LT2016U Hard Drive Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
91
All Time:
2,193
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
With a Phillips #0 screwdriver, the hard drive can easily be replaced.
Tools
    1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 1 of 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 2 of 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Unlock the tab located in the top left corner of the netbook.
      • The red tab indicated that the battery has been properly unlocked.
      • Remove the battery.
      • When working with electronics, it is always wise to remove the power source before taking the device apart.
      Ask FixBot
    1. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
      • The hard drive is located under this cover.
      Ask FixBot
    2. Gateway KAV60 LT2016U Hard Drive Replacement: step 3, image 1 of 2 Gateway KAV60 LT2016U Hard Drive Replacement: step 3, image 2 of 2
      • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
      Ask FixBot
    3. Gateway KAV60 LT2016U Hard Drive Replacement: step 4, image 1 of 2 Gateway KAV60 LT2016U Hard Drive Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to lift the cover.
      Ask FixBot
    4. Gateway KAV60 LT2016U Hard Drive Replacement: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
      Ask FixBot
    5. Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 1 of 3 Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 2 of 3 Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 3 of 3
      • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
      • Lift the silver cover; this will expose the hard drive.
      Ask FixBot
Lydia Benjock
1,255 Reputation
10 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 91
All Time: 2,193
