Up to 20% off select tools
Gateway ID49C07U Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
94
All Time:
883
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Gateway ID49C07U Screen Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
      Ask FixBot
    2. Gateway ID49C07U Screen Replacement: step 2, image 1 of 2 Gateway ID49C07U Screen Replacement: step 2, image 2 of 2
      • Locate the switch on the top left of the laptop labeled with a padlock symbol.
      • Flip the switch in the direction of the unlocked padlock symbol.
      Ask FixBot
    3. Gateway ID49C07U Screen Replacement: step 3, image 1 of 1
      • Locate the switch that releases the battery and slide it to the right.
      Ask FixBot
    4. Gateway ID49C07U Screen Replacement: step 4, image 1 of 1
      • While holding the release switch to the right, pull the battery away from you.
      Ask FixBot
    1. Gateway ID49C07U Screen Replacement, Screen: step 5, image 1 of 1
      • Turn the laptop over and open.
      Ask FixBot
    2. Gateway ID49C07U Screen Replacement: step 6, image 1 of 2 Gateway ID49C07U Screen Replacement: step 6, image 2 of 2
      • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
      Ask FixBot
    3. Gateway ID49C07U Screen Replacement: step 7, image 1 of 2 Gateway ID49C07U Screen Replacement: step 7, image 2 of 2
      • Use the PH1 Screwdriver to remove the screws
      Ask FixBot
    4. Gateway ID49C07U Screen Replacement: step 8, image 1 of 1
      • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
      Ask FixBot
    5. Gateway ID49C07U Screen Replacement: step 9, image 1 of 3 Gateway ID49C07U Screen Replacement: step 9, image 2 of 3 Gateway ID49C07U Screen Replacement: step 9, image 3 of 3
      • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
      Ask FixBot
    6. Gateway ID49C07U Screen Replacement: step 10, image 1 of 3 Gateway ID49C07U Screen Replacement: step 10, image 2 of 3 Gateway ID49C07U Screen Replacement: step 10, image 3 of 3
      • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
      Ask FixBot
    7. Gateway ID49C07U Screen Replacement: step 11, image 1 of 2 Gateway ID49C07U Screen Replacement: step 11, image 2 of 2
      • After the screws are out gently flip the screen over onto the keyboard
      Ask FixBot
    8. Gateway ID49C07U Screen Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
      Ask FixBot
    9. Gateway ID49C07U Screen Replacement: step 13, image 1 of 2 Gateway ID49C07U Screen Replacement: step 13, image 2 of 2
      • Hold the tape back with one hand and pull the connector out
      Ask FixBot
2 other people completed this guide.
Author
with
Ryan Howlett
273 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 94
All Time: 883
