Up to 20% off select tools
Gateway ID49C07U RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
90
All Time:
1,004
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Gateway ID49C07U RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
      Ask FixBot
    2. Gateway ID49C07U RAM Replacement: step 2, image 1 of 2 Gateway ID49C07U RAM Replacement: step 2, image 2 of 2
      • Locate the switch on the top left of the laptop labeled with a padlock symbol.
      • Flip the switch in the direction of the unlocked padlock symbol.
      Ask FixBot
    3. Gateway ID49C07U RAM Replacement: step 3, image 1 of 1
      • Locate the switch that releases the battery and slide it to the right.
      Ask FixBot
    4. Gateway ID49C07U RAM Replacement: step 4, image 1 of 1
      • While holding the release switch to the right, pull the battery away from you.
      Ask FixBot
    1. Gateway ID49C07U RAM Replacement, RAM: step 5, image 1 of 2 Gateway ID49C07U RAM Replacement, RAM: step 5, image 2 of 2
      • Locate two screws securing back panel
      • Unscrew both
      Ask FixBot
    2. Gateway ID49C07U RAM Replacement: step 6, image 1 of 2 Gateway ID49C07U RAM Replacement: step 6, image 2 of 2
      • Remove plate from device
      Ask FixBot
    3. Gateway ID49C07U RAM Replacement: step 7, image 1 of 2 Gateway ID49C07U RAM Replacement: step 7, image 2 of 2
      • Locate RAM
      • Push tabs apart to release memory
      Ask FixBot
    4. Gateway ID49C07U RAM Replacement: step 8, image 1 of 1
      • Pull out memory
      Ask FixBot
2 other people completed this guide.
Author
with
Patrick McGrail
466 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 90
All Time: 1,004
