Up to 20% off select tools
Gateway ID49C07U Keyboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
79
All Time:
1,131
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Gateway ID49C07U Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
      Ask FixBot
    2. Gateway ID49C07U Keyboard Replacement: step 2, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 2, image 2 of 2
      • Locate the switch on the top left of the laptop labeled with a padlock symbol.
      • Flip the switch in the direction of the unlocked padlock symbol.
      Ask FixBot
    3. Gateway ID49C07U Keyboard Replacement: step 3, image 1 of 1
      • Locate the switch that releases the battery and slide it to the right.
      Ask FixBot
    4. Gateway ID49C07U Keyboard Replacement: step 4, image 1 of 1
      • While holding the release switch to the right, pull the battery away from you.
      Ask FixBot
    1. Gateway ID49C07U Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Turn the laptop over and open
      Ask FixBot
    2. Gateway ID49C07U Keyboard Replacement: step 6, image 1 of 3 Gateway ID49C07U Keyboard Replacement: step 6, image 2 of 3 Gateway ID49C07U Keyboard Replacement: step 6, image 3 of 3
      • Use the small metal spudger to push in each of the clips on the keyboard
      Ask FixBot
    3. Gateway ID49C07U Keyboard Replacement: step 7, image 1 of 3 Gateway ID49C07U Keyboard Replacement: step 7, image 2 of 3 Gateway ID49C07U Keyboard Replacement: step 7, image 3 of 3
      • Continued
      Ask FixBot
    4. Gateway ID49C07U Keyboard Replacement: step 8, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 8, image 2 of 2
      • Use the small spudger to pick up the corner
      Ask FixBot
    5. Gateway ID49C07U Keyboard Replacement: step 9, image 1 of 1
      • Slide keyboard towards the screen
      Ask FixBot
    6. Gateway ID49C07U Keyboard Replacement: step 10, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 10, image 2 of 2
      • Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
      Ask FixBot
2 other people completed this guide.
Author
with
Ryan Howlett
273 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 79
All Time: 1,131
