Gateway ID49C07U DVD Drive Replacement
    1. Gateway ID49C07U DVD Drive Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
      Ask FixBot
    2. Gateway ID49C07U DVD Drive Replacement: step 2, image 1 of 2 Gateway ID49C07U DVD Drive Replacement: step 2, image 2 of 2
      • Locate the switch on the top left of the laptop labeled with a padlock symbol.
      • Flip the switch in the direction of the unlocked padlock symbol.
      Ask FixBot
    3. Gateway ID49C07U DVD Drive Replacement: step 3, image 1 of 1
      • Locate the switch that releases the battery and slide it to the right.
      Ask FixBot
    4. Gateway ID49C07U DVD Drive Replacement: step 4, image 1 of 1
      • While holding the release switch to the right, pull the battery away from you.
      Ask FixBot
    1. Gateway ID49C07U DVD Drive Replacement, DVD Drive: step 5, image 1 of 1
      • Locate screw towards the center of the device and unscrew it
      Ask FixBot
    2. Gateway ID49C07U DVD Drive Replacement: step 6, image 1 of 3 Gateway ID49C07U DVD Drive Replacement: step 6, image 2 of 3 Gateway ID49C07U DVD Drive Replacement: step 6, image 3 of 3
      • Use a metal spudger to pry off the DVD drive.
      • Once loosened, use your hand to pull the DVD drive out.
      Ask FixBot
2 other people completed this guide.
Patrick McGrail
466 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 93
All Time: 632
