Gateway GWTC116-2BL Touchpad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
82
All Time:
653
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your touchpad on the Gateway GWTC116-2BL is not working, there may be a problem with it. There could be a possibility it has been damaged, and you need to replace it. In this guide, there is a step-by-step of how to replace a faulty touchpad. Be sure to have a new touchpad that is compatible with the Gateway GWTC116-2BL handy in order to replace the faulty one.
Tools
    1. Gateway GWTC116-2BL Touchpad Replacement, Back Panel: step 1, image 1 of 1
      • Ground yourself before disassembling and handling the computer.
      • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
      Ask FixBot
    2. Gateway GWTC116-2BL Touchpad Replacement: step 2, image 1 of 2 Gateway GWTC116-2BL Touchpad Replacement: step 2, image 2 of 2
      • Use the spudger to pry the back panel away from the body of the laptop.
      Ask FixBot
    1. Gateway GWTC116-2BL Touchpad Replacement, Battery: step 3, image 1 of 1
      • Remove the five 3.0 mm Phillips #00 screws.
      Ask FixBot
    2. Gateway GWTC116-2BL Touchpad Replacement: step 4, image 1 of 2 Gateway GWTC116-2BL Touchpad Replacement: step 4, image 2 of 2
      • Using your fingers, flick open the battery connector bracket.
      • Remove the connector from bracket.
      Ask FixBot
    3. Gateway GWTC116-2BL Touchpad Replacement: step 5, image 1 of 1
      • Pull up the battery to remove from the base.
      Ask FixBot
    1. Gateway GWTC116-2BL Touchpad Replacement, Touchpad: step 6, image 1 of 2 Gateway GWTC116-2BL Touchpad Replacement, Touchpad: step 6, image 2 of 2
      • Flick open the bracket and peel back the white cable.
      Ask FixBot
    2. Gateway GWTC116-2BL Touchpad Replacement: step 7, image 1 of 2 Gateway GWTC116-2BL Touchpad Replacement: step 7, image 2 of 2
      • Peel the metallic tape off of the casing.
      Ask FixBot
    3. Gateway GWTC116-2BL Touchpad Replacement: step 8, image 1 of 1
      • Peel off the smaller piece of metallic tape that was underneath the other tape.
      Ask FixBot
    4. Gateway GWTC116-2BL Touchpad Replacement: step 9, image 1 of 2 Gateway GWTC116-2BL Touchpad Replacement: step 9, image 2 of 2
      • Using an opening tool, dislocate the touchpad from the adhesive part of the base.
      • Repeat on the other side.
      Ask FixBot
    5. Gateway GWTC116-2BL Touchpad Replacement: step 10, image 1 of 1
      • Pull away the touchpad from the base of the computer.
      Ask FixBot
Kailey Sousa
522 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 82
All Time: 653
