Gateway GWTC116-2BL Display Replacement
    1. Gateway GWTC116-2BL Display Replacement, Back Panel: step 1, image 1 of 1
      • Ground yourself before disassembling and handling the computer.
      • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
      Ask FixBot
    2. Gateway GWTC116-2BL Display Replacement: step 2, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 2, image 2 of 2
      • Use the spudger to pry the back panel away from the body of the laptop.
      Ask FixBot
    1. Gateway GWTC116-2BL Display Replacement, Battery: step 3, image 1 of 1
      • Remove the five 3.0 mm Phillips #00 screws.
      Ask FixBot
    2. Gateway GWTC116-2BL Display Replacement: step 4, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 4, image 2 of 2
      • Using your fingers, flick open the battery connector bracket.
      • Remove the connector from bracket.
      Ask FixBot
    3. Gateway GWTC116-2BL Display Replacement: step 5, image 1 of 1
      • Pull up the battery to remove from the base.
      Ask FixBot
    1. Gateway GWTC116-2BL Display Replacement, Motherboard: step 6, image 1 of 1
      • Using your fingers, flick the cable connector bracket open.
      • Remove the cable from the connector.
      Ask FixBot
    2. Gateway GWTC116-2BL Display Replacement: step 7, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 7, image 2 of 2
      • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
      Ask FixBot
    3. Gateway GWTC116-2BL Display Replacement: step 8, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 8, image 2 of 2
      • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
      Ask FixBot
    4. Gateway GWTC116-2BL Display Replacement: step 9, image 1 of 3 Gateway GWTC116-2BL Display Replacement: step 9, image 2 of 3 Gateway GWTC116-2BL Display Replacement: step 9, image 3 of 3
      • Peel the yellow tape off of the casing.
      • Lift the casing off of the motherboard.
      Ask FixBot
    5. Gateway GWTC116-2BL Display Replacement: step 10, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 10, image 2 of 2
      • Peel off the yellow tape.
      • Remove four 3.0 mm Phillips #00 screws.
      Ask FixBot
    6. Gateway GWTC116-2BL Display Replacement: step 11, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 11, image 2 of 2
      • Peel off the black piece of tape covering the display cable.
      Ask FixBot
    7. Gateway GWTC116-2BL Display Replacement: step 12, image 1 of 2 Gateway GWTC116-2BL Display Replacement: step 12, image 2 of 2
      • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
      Ask FixBot
    8. Gateway GWTC116-2BL Display Replacement: step 13, image 1 of 1
      • Remove the motherboard from the device.
      Ask FixBot
    1. Gateway GWTC116-2BL Display Replacement, Display: step 14, image 1 of 1
      • Remove seven 3.0 mm Phillips #00 screws from the laptop.
      Ask FixBot
    2. Gateway GWTC116-2BL Display Replacement: step 15, image 1 of 1
      • Applying some force, use your hands to pry the display of the laptop away from the base.
      Ask FixBot
Kailey Sousa
522 Reputation
4 Guides authored
1 Guide Comment
Mon écran ne s'allume pas au démarrage. Que faire ?
Youssouf SAWADOGO - Reply Share
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 102
All Time: 1,643
