Gateway GWTC116-2BL Daughterboard Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
86
All Time:
801
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Gateway GWTC116-2BL laptop is experiencing issues with its daughterboard, replacing it might be necessary. The daughterboard is an essential component that connects the motherboard to other peripherals, such as the keyboard, touchpad, and USB ports. Faulty daughterboards can cause several problems, including malfunctioning laptop peripherals. Replacing a Gateway GWTC116-2BL daughterboard is a simple process that involves a few steps. In this guide, we'll outline the steps you need to take to replace the daughterboard and get your laptop functioning normally again.
Tools
    1. Gateway GWTC116-2BL Daughterboard Replacement, Back Panel: step 1, image 1 of 1
      • Ground yourself before disassembling and handling the computer.
      • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
      Ask FixBot
    2. Gateway GWTC116-2BL Daughterboard Replacement: step 2, image 1 of 2 Gateway GWTC116-2BL Daughterboard Replacement: step 2, image 2 of 2
      • Use the spudger to pry the back panel away from the body of the laptop.
      Ask FixBot
    1. Gateway GWTC116-2BL Daughterboard Replacement, Battery: step 3, image 1 of 1
      • Remove the five 3.0 mm Phillips #00 screws.
      Ask FixBot
    2. Gateway GWTC116-2BL Daughterboard Replacement: step 4, image 1 of 2 Gateway GWTC116-2BL Daughterboard Replacement: step 4, image 2 of 2
      • Using your fingers, flick open the battery connector bracket.
      • Remove the connector from bracket.
      Ask FixBot
    3. Gateway GWTC116-2BL Daughterboard Replacement: step 5, image 1 of 1
      • Pull up the battery to remove from the base.
      Ask FixBot
    1. Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: step 6, image 1 of 2 Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: step 6, image 2 of 2
      • Peel off the yellow piece of tape that is placed over the daughterboard.
      Ask FixBot
    2. Gateway GWTC116-2BL Daughterboard Replacement: step 7, image 1 of 1
      • Remove the three 3.0 mm Phillips #00 screws.
      Ask FixBot
    3. Gateway GWTC116-2BL Daughterboard Replacement: step 8, image 1 of 2 Gateway GWTC116-2BL Daughterboard Replacement: step 8, image 2 of 2
      • Flick open the bracket that connects the motherboard and daughterboard.
      • Remove the connector strip.
      Ask FixBot
    4. Gateway GWTC116-2BL Daughterboard Replacement: step 9, image 1 of 1
      • Remove the daughterboard from the base of the computer.
      Ask FixBot
Kailey Sousa
522 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 86
All Time: 801
