Gateway GWTC116-2BL Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
33
Past 30 Days:
125
All Time:
1,707
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace a worn out battery for your Gateway GWTC116-2BL laptop. If your computer is shutting down randomly, this may mean you need a new battery. Overheating of your computer means your computer is working too hard. This guide will show you a simplified step-by-step break down to replace your battery. Before starting this replacement guide, be sure to be grounded before handling the battery.
Tools
    1. Gateway GWTC116-2BL Battery Replacement, Back Panel: step 1, image 1 of 1
      • Ground yourself before disassembling and handling the computer.
      • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
      Ask FixBot
    2. Gateway GWTC116-2BL Battery Replacement: step 2, image 1 of 2 Gateway GWTC116-2BL Battery Replacement: step 2, image 2 of 2
      • Use the spudger to pry the back panel away from the body of the laptop.
      Ask FixBot
    1. Gateway GWTC116-2BL Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the five 3.0 mm Phillips #00 screws.
      Ask FixBot
    2. Gateway GWTC116-2BL Battery Replacement: step 4, image 1 of 2 Gateway GWTC116-2BL Battery Replacement: step 4, image 2 of 2
      • Using your fingers, flick open the battery connector bracket.
      • Remove the connector from bracket.
      Ask FixBot
    3. Gateway GWTC116-2BL Battery Replacement: step 5, image 1 of 1
      • Pull up the battery to remove from the base.
      Ask FixBot
2 other people completed this guide.
Kailey Sousa
522 Reputation
4 Guides authored
1 Guide Comment
Donde puedo adquirir esta bateria Aqui en nicaragua
Jose a berrios - Reply Share
Past 24 Hours: 1
Past 7 Days: 33
Past 30 Days: 125
All Time: 1,707
