Up to 20% off select tools
Gateway 600YG2 System Board Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
93
All Time:
3,570
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
removal of the system board
    1. Gateway 600YG2 System Board Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over.
      • Slide the battery release tab to the right to open the battery cover.
      Ask FixBot
    2. Gateway 600YG2 System Board Replacement: step 2, image 1 of 1
      • Remove the battery cover using the tab on the right side.
      • Lift and remove the battery.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, CD/DVD or Floppy drives: step 3, image 1 of 1
      • Slide the release and push the button to eject the drive.
      • Remove the drive.
      • When reinserting the drives, put them in the original slot to avoid interface conflicts.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, Hard Drive: step 4, image 1 of 1
      • Unscrew 1 captive screw holding hard drive cover on.
      • Slide hard drive to the right and remove.
      • For detailed pictures and info view Gateway Support
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, Power Button Panel: step 5, image 1 of 1
      • Insert the spudger between the "sysrq" and "ins" keys.
      • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, LCD: step 6, image 1 of 1
      • Remove the five screws with a Phillips #0 screwdriver.
      • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
      • Lift the hinge covers along the outer edges with the spudger until they are released.
      Ask FixBot
    2. Gateway 600YG2 System Board Replacement: step 7, image 1 of 1
      • Gently unplug the LCD from the system board.
      Ask FixBot
    3. Gateway 600YG2 System Board Replacement: step 8, image 1 of 1
      • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
      Ask FixBot
    4. Gateway 600YG2 System Board Replacement: step 9, image 1 of 1
      • Check if any cables are still connected before pulling out the LCD.
      • Remove the cable by gently pulling it out while holding down the LCD.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, Keyboard: step 10, image 1 of 1
      • Remove the five screws holding the keyboard in place.
      Ask FixBot
    2. Gateway 600YG2 System Board Replacement: step 11, image 1 of 2 Gateway 600YG2 System Board Replacement: step 11, image 2 of 2
      • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
      • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
      • Follow the black ribbon cable and gently pull straight up.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, System Fan: step 12, image 1 of 2 Gateway 600YG2 System Board Replacement, System Fan: step 12, image 2 of 2
      • Unscrew the four captive screws.
      • Unplug the fan from the system and pull it out. This should slide forward before coming free.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, Top Case: step 13, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
      Ask FixBot
    2. Gateway 600YG2 System Board Replacement: step 14, image 1 of 1
      • Remove the two indicated screws.
      Ask FixBot
    3. Gateway 600YG2 System Board Replacement: step 15, image 1 of 1
      • Remove the four screws from the back of the case.
      Ask FixBot
    4. Gateway 600YG2 System Board Replacement: step 16, image 1 of 1
      • Potential for device damage: Failure to properly do this step will damage your mouse pad ribbon.
      • Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
      • Remove the ribbon.
      Ask FixBot
    5. Gateway 600YG2 System Board Replacement: step 17, image 1 of 1
      • Insert your spudger between the upper and lower case at the drive bay closest to the battery.
      • Carefully go around the entire case, unseating all plastic clips holding the upper and lower cases together.
      Ask FixBot
    6. Gateway 600YG2 System Board Replacement: step 18, image 1 of 1
      • Lift the upper case about 1/4 inch.
      • Unplug the last connecting wire and remove the upper case.
      Ask FixBot
    1. Gateway 600YG2 System Board Replacement, System Board: step 19, image 1 of 2 Gateway 600YG2 System Board Replacement, System Board: step 19, image 2 of 2
      • Remove eight screws from drive bays.
      Ask FixBot
    2. Gateway 600YG2 System Board Replacement: step 20, image 1 of 1
      • Remove six 5mm hex nuts from back of laptop.
      Ask FixBot
    3. Gateway 600YG2 System Board Replacement: step 21, image 1 of 1
      • Remove screw.
      • Slide metal clip into battery bay.
      Ask FixBot
    4. Gateway 600YG2 System Board Replacement: step 22, image 1 of 1
      • Remove two screws.
      • Hard drive extension should lift out from system board.
      Ask FixBot
    5. Gateway 600YG2 System Board Replacement: step 23, image 1 of 1
      • Remove four screws holding left speaker to ease access to connectors and external sound board.
      Ask FixBot
    6. Gateway 600YG2 System Board Replacement: step 24, image 1 of 1
      • Remove screw and unplug speakers from external sound board.
      • Lift external soundboard away from system board and remove.
      Ask FixBot
    7. Gateway 600YG2 System Board Replacement: step 25, image 1 of 1
      • Unplug audio DJ
      • Unplug System status light board
      • Starting on the right side of case gently lift and slide system board till it comes free of lower case.
      Ask FixBot
Author
with
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 93
All Time: 3,570
