Up to 20% off select tools
Gateway 600YG2 Power Button Panel Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
94
All Time:
2,973
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If the power button doesn't work when you press it to power on your laptop, the power button panel may need to be replaced. The power button panel is where the power button and other buttons are located. Once replaced it should run smoothly.
Before you replace it, make sure that it's not another issue such as a dead battery, out-of-date software, etc.
Follow this guide to replace the power button panel of your Gateway 600YG2 laptop. This guide will walk you through the steps.
Before you start the guide, just make sure the laptop is off and isn't connected to the charging adaptor or peripherals.
    1. Gateway 600YG2 Power Button Panel Replacement, Power Button Panel: step 1, image 1 of 1
      • Insert the spudger between the "sysrq" and "ins" keys.
      • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 94
All Time: 2,973
