Up to 20% off select tools
Gateway 600YG2 LCD Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
86
All Time:
2,667
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Replace a faulty display on your Gateway 600YG2 using this guide. If the glass on your display cracks or breaks, it may need to be replaced. Before using this guide, inspect the display for any swelling and check software compatibility. This could harm the computer's liquid crystal display (LCD) capabilities. The LCD is an energy-efficient liquid organic material with long-lasting LED backlighting, no screen burn (deteriorated pixels from overuse), and adaptable file sizes.
To disassemble electronic components in step 1 of this guide, you will need a Phillips #0 Screwdriver (identified as piece number IF145-005). Sprunger (identified as piece number IF145-002) will also be required to pry open the pieces.
Turn off your laptop and disconnect it from any power sources before beginning the process.
    1. Gateway 600YG2 LCD Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over.
      • Slide the battery release tab to the right to open the battery cover.
      Ask FixBot
    2. Gateway 600YG2 LCD Replacement: step 2, image 1 of 1
      • Remove the battery cover using the tab on the right side.
      • Lift and remove the battery.
      Ask FixBot
    1. Gateway 600YG2 LCD Replacement, Power Button Panel: step 3, image 1 of 1
      • Insert the spudger between the "sysrq" and "ins" keys.
      • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
      Ask FixBot
    1. Gateway 600YG2 LCD Replacement, LCD: step 4, image 1 of 1
      • Remove the five screws with a Phillips #0 screwdriver.
      • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
      • Lift the hinge covers along the outer edges with the spudger until they are released.
      Ask FixBot
    2. Gateway 600YG2 LCD Replacement: step 5, image 1 of 1
      • Gently unplug the LCD from the system board.
      Ask FixBot
    3. Gateway 600YG2 LCD Replacement: step 6, image 1 of 1
      • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
      Ask FixBot
    4. Gateway 600YG2 LCD Replacement: step 7, image 1 of 1
      • Check if any cables are still connected before pulling out the LCD.
      • Remove the cable by gently pulling it out while holding down the LCD.
      Ask FixBot
Author
with
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 86
All Time: 2,667
