Up to 20% off select tools
Gateway 600YG2 Keyboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
93
All Time:
2,167
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The Gateway 600 YG2 includes a full-sized 86-key keyboard. Each key performs a specific function when pressed individually or in combination with other keys.
Follow the steps in this guide to replace your keyboard if necessary.
New or pre-owned keyboards can be purchased on eBay. An original factor laptop full complete keyboard with a 2-year protection plan can be purchased for $14.99.
Source: Keyboard Area - Gateway 600Y G2 User Manual
    1. Gateway 600YG2 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over.
      • Slide the battery release tab to the right to open the battery cover.
      Ask FixBot
    2. Gateway 600YG2 Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery cover using the tab on the right side.
      • Lift and remove the battery.
      Ask FixBot
    1. Gateway 600YG2 Keyboard Replacement, Power Button Panel: step 3, image 1 of 1
      • Insert the spudger between the "sysrq" and "ins" keys.
      • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
      Ask FixBot
    1. Gateway 600YG2 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Remove the five screws holding the keyboard in place.
      Ask FixBot
    2. Gateway 600YG2 Keyboard Replacement: step 5, image 1 of 2 Gateway 600YG2 Keyboard Replacement: step 5, image 2 of 2
      • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
      • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
      • Follow the black ribbon cable and gently pull straight up.
      Ask FixBot
Author
with
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 93
All Time: 2,167
