Gateway 3545GZ Hard Drive Replacement
    1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
      • Screw Length: 3mm
      Ask FixBot
    2. Gateway 3545GZ Hard Drive Replacement: step 2, image 1 of 1
      • Lift up the plastic plate from the outer edge.
      Ask FixBot
    3. Gateway 3545GZ Hard Drive Replacement: step 3, image 1 of 1
      • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
      Ask FixBot
Bryan Rickle
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 568
