Garmin nuvi 2460 LMT Screen Replacement
    1. Garmin nuvi 2460 LMT Screen Replacement, Back Cover: step 1, image 1 of 2 Garmin nuvi 2460 LMT Screen Replacement, Back Cover: step 1, image 2 of 2
      • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
      Ask FixBot
    2. Garmin nuvi 2460 LMT Screen Replacement: step 2, image 1 of 1
      • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
      Ask FixBot
    3. Garmin nuvi 2460 LMT Screen Replacement: step 3, image 1 of 1
      • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
      Ask FixBot
    4. Garmin nuvi 2460 LMT Screen Replacement: step 4, image 1 of 1
      • Lift the connector gently from the socket, making sure you pull in the right direction.
      Ask FixBot
    1. Garmin nuvi 2460 LMT Screen Replacement, Screen: step 5, image 1 of 1
      • Pop out the panel along the edges and remove it from the border.
      Ask FixBot
Ricardo Audain
671 Reputation
5 Guides authored
USF Tampa, Team 6-4, Remmell Fall 2016 Member of USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 42
All Time: 776
