Garmin inReach Mini Battery Replacement
Views: 8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
41
Past 30 Days:
186
All Time:
7,969
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the battery of a Garmin inReach Mini. This devices utilizes a rechargeable, lithium ion battery. The battery is located on the inside of the back hard case. When removing the battery, make sure all necessary cables and power sources are disconnected from the battery in order to prevent an electrical hazard. After replacing the battery, it is crucial to dispose of the old battery at a specialized e-waste collection site or battery-recycling location.
Tools
    1. Garmin inReach Mini Battery Replacement, Nylon Strap: step 1, image 1 of 1
      • Place the device on a level surface with the back hard case facing up.
      Ask FixBot
    2. Garmin inReach Mini Battery Replacement: step 2, image 1 of 3 Garmin inReach Mini Battery Replacement: step 2, image 2 of 3 Garmin inReach Mini Battery Replacement: step 2, image 3 of 3
      • Use the T5 to remove the 1.9mm screw attached to the nylon strap.
      • Remove the nylon strap.
      Ask FixBot
    1. Garmin inReach Mini Battery Replacement, Back Case: step 3, image 1 of 3 Garmin inReach Mini Battery Replacement, Back Case: step 3, image 2 of 3 Garmin inReach Mini Battery Replacement, Back Case: step 3, image 3 of 3
      • Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
      Ask FixBot
    2. Garmin inReach Mini Battery Replacement: step 4, image 1 of 3 Garmin inReach Mini Battery Replacement: step 4, image 2 of 3 Garmin inReach Mini Battery Replacement: step 4, image 3 of 3
      • Lastly, lift the protective cap on the side of the device that states "SOS". Slowly pull it to the right in order to remove the back hard case.
      Ask FixBot
    3. Garmin inReach Mini Battery Replacement: step 5, image 1 of 3 Garmin inReach Mini Battery Replacement: step 5, image 2 of 3 Garmin inReach Mini Battery Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Using the precision tweezers with the round tips, detach the battery connector from the motherboard.
      • Disconnecting the battery stops the flow of power into the motherboard. This is for your own safety.
      • If utilizing this guide as a prerequisite to replacing the motherboard, it is crucial not to damage the cable connecting the battery to the motherboard. When the new motherboard is introduced, it will need to be reconnected with that cable.
      Ask FixBot
    1. Garmin inReach Mini Battery Replacement, Battery: step 6, image 1 of 3 Garmin inReach Mini Battery Replacement, Battery: step 6, image 2 of 3 Garmin inReach Mini Battery Replacement, Battery: step 6, image 3 of 3
      • After removing the back hard case, users can access the battery on the inside of the back hard case.
      • Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
      Ask FixBot
    2. Garmin inReach Mini Battery Replacement: step 7, image 1 of 2 Garmin inReach Mini Battery Replacement: step 7, image 2 of 2
      • Create leverage by inserting the opening tool underneath the battery. Lift the battery up until it detaches from the case, then remove the battery entirely.
      Ask FixBot
    3. Garmin inReach Mini Battery Replacement: step 8, image 1 of 1
      Buy
      • Then using the precision tweezers with the round tips, lightly pull the battery out from the case.
      • The battery is attached to the back hard case with an adhesive.
      • Dispose of the lithium ion battery in a safe manner in order to prevent electrical hazards. Keep the battery dry and cool.
      Ask FixBot
6 other people completed this guide.
Ellie Taube
553 Reputation
4 Guides authored
2 Guide Comments
Any idea where to buy a replacement motherboard? The battery in mine corroded and the battery connector broke off.
Ashley Hill - Reply Share
where to buy the battery from? is it the same battery for Garmin inReach Mini 2?
Akkad - Reply Share
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 186
All Time: 7,969
