Garmin inReach Explorer Plus LCD Screen Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
77
All Time:
1,914
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will be used if your Garmin inReach Explorer+ has screen issues. The guide will go over the process to replace the LCD screen. The LCD screen is a key component of the GPS, showing the visuals of the GPS and any selections that are made with the buttons.
As mentioned in our troubleshooting guide, the screen issues could be a frozen or damaged screen. The troubleshooting guide has several solutions that should be attempted prior to replacing the screen such as performing updating the device and resetting the device.
Before you begin replacing the screen, make sure it is powered off and it is not connected to any other form of power.
Tools
    1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
      Ask FixBot
    2. Garmin inReach Explorer Plus LCD Screen Replacement: step 2, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    3. Garmin inReach Explorer Plus LCD Screen Replacement: step 3, image 1 of 2 Garmin inReach Explorer Plus LCD Screen Replacement: step 3, image 2 of 2
      • Gently grasp the battery wire and disconnect it from the device.
      • Remove the battery from the device.
      Ask FixBot
    1. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: step 4, image 1 of 2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: step 4, image 2 of 2
      • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
      Ask FixBot
    2. Garmin inReach Explorer Plus LCD Screen Replacement: step 5, image 1 of 2 Garmin inReach Explorer Plus LCD Screen Replacement: step 5, image 2 of 2
      • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
      • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
      Ask FixBot
    3. Garmin inReach Explorer Plus LCD Screen Replacement: step 6, image 1 of 2 Garmin inReach Explorer Plus LCD Screen Replacement: step 6, image 2 of 2
      • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
      Ask FixBot
    4. Garmin inReach Explorer Plus LCD Screen Replacement: step 7, image 1 of 3 Garmin inReach Explorer Plus LCD Screen Replacement: step 7, image 2 of 3 Garmin inReach Explorer Plus LCD Screen Replacement: step 7, image 3 of 3
      • Gently lift the motherboard up and out of the device.
      Ask FixBot
    1. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: step 8, image 1 of 2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: step 8, image 2 of 2
      • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
      Ask FixBot
    2. Garmin inReach Explorer Plus LCD Screen Replacement: step 9, image 1 of 3 Garmin inReach Explorer Plus LCD Screen Replacement: step 9, image 2 of 3 Garmin inReach Explorer Plus LCD Screen Replacement: step 9, image 3 of 3
      • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
      Ask FixBot
Sean Kelley
387 Reputation
4 Guides authored
Clemson, Team 5-4, Hunter Fall 2021 Member of Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Members
60 Guides authored
3 Guide Comments
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Reply Share
Ditto - where can we get a screen??
Ben Wallbank - Reply Share
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 77
All Time: 1,914
