Garmin inReach Explorer Plus Button Pad Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
42
All Time:
567
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
The Garmin inReach Explorer Plus is a backcountry GPS device. This guide shows how to remove and replace the button pad of the Garmin inReach Explorer Plus. The button pad allows the user to input commands for the device to send messages or access settings. See our troubleshooting page here for possible symptoms. WARNING: Before disassembling device, make sure that the device is turned off and there are no signs of a swollen battery or shattered glass in the device.
Tools
    1. Garmin inReach Explorer Plus Button Pad Replacement, Battery: step 1, image 1 of 1
      • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
      Ask FixBot
    2. Garmin inReach Explorer Plus Button Pad Replacement: step 2, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    3. Garmin inReach Explorer Plus Button Pad Replacement: step 3, image 1 of 2 Garmin inReach Explorer Plus Button Pad Replacement: step 3, image 2 of 2
      • Gently grasp the battery wire and disconnect it from the device.
      • Remove the battery from the device.
      Ask FixBot
    1. Garmin inReach Explorer Plus Button Pad Replacement, Motherboard: step 4, image 1 of 2 Garmin inReach Explorer Plus Button Pad Replacement, Motherboard: step 4, image 2 of 2
      • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
      Ask FixBot
    2. Garmin inReach Explorer Plus Button Pad Replacement: step 5, image 1 of 2 Garmin inReach Explorer Plus Button Pad Replacement: step 5, image 2 of 2
      • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
      • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
      Ask FixBot
    3. Garmin inReach Explorer Plus Button Pad Replacement: step 6, image 1 of 2 Garmin inReach Explorer Plus Button Pad Replacement: step 6, image 2 of 2
      • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
      Ask FixBot
    4. Garmin inReach Explorer Plus Button Pad Replacement: step 7, image 1 of 3 Garmin inReach Explorer Plus Button Pad Replacement: step 7, image 2 of 3 Garmin inReach Explorer Plus Button Pad Replacement: step 7, image 3 of 3
      • Gently lift the motherboard up and out of the device.
      Ask FixBot
    1. Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: step 8, image 1 of 3 Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: step 8, image 2 of 3 Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: step 8, image 3 of 3
      • After the motherboard is removed, make sure the wire is out of the way of the button pad.
      • Flip the device over and push down on the button pad to remove it from the device.
      Ask FixBot
Sean Kelley
387 Reputation
4 Guides authored
Clemson, Team 5-4, Hunter Fall 2021 Member of Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 42
All Time: 567
