Garmin inReach Explorer Plus Antenna Replacement
  1. Garmin inReach Explorer Plus Antenna Replacement, Battery: step 1, image 1 of 1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
    Ask FixBot
  2. Garmin inReach Explorer Plus Antenna Replacement: step 2, image 1 of 1
    • Remove the back cover.
    Ask FixBot
  3. Garmin inReach Explorer Plus Antenna Replacement: step 3, image 1 of 2 Garmin inReach Explorer Plus Antenna Replacement: step 3, image 2 of 2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
    Ask FixBot
  4. Garmin inReach Explorer Plus Antenna Replacement, Motherboard: step 4, image 1 of 2 Garmin inReach Explorer Plus Antenna Replacement, Motherboard: step 4, image 2 of 2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
    Ask FixBot
  5. Garmin inReach Explorer Plus Antenna Replacement: step 5, image 1 of 2 Garmin inReach Explorer Plus Antenna Replacement: step 5, image 2 of 2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
    Ask FixBot
  6. Garmin inReach Explorer Plus Antenna Replacement: step 6, image 1 of 2 Garmin inReach Explorer Plus Antenna Replacement: step 6, image 2 of 2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
    Ask FixBot
  7. Garmin inReach Explorer Plus Antenna Replacement: step 7, image 1 of 3 Garmin inReach Explorer Plus Antenna Replacement: step 7, image 2 of 3 Garmin inReach Explorer Plus Antenna Replacement: step 7, image 3 of 3
    • Gently lift the motherboard up and out of the device.
    Ask FixBot
  8. Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: step 8, image 1 of 2 Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: step 8, image 2 of 2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
    Ask FixBot
  9. Garmin inReach Explorer Plus Antenna Replacement: step 9, image 1 of 3 Garmin inReach Explorer Plus Antenna Replacement: step 9, image 2 of 3 Garmin inReach Explorer Plus Antenna Replacement: step 9, image 3 of 3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
    Ask FixBot
  10. Garmin inReach Explorer Plus Antenna Replacement, Antenna: step 10, image 1 of 3 Garmin inReach Explorer Plus Antenna Replacement, Antenna: step 10, image 2 of 3 Garmin inReach Explorer Plus Antenna Replacement, Antenna: step 10, image 3 of 3
    • Gently pull out the antenna wire and remove the antenna from the device.
    • The antenna should now slide out easily. If the antenna is stuck, use the spudger to gently dislodge the antenna from its housing.
    Ask FixBot
Sean Kelley
387 Reputation
4 Guides authored
Clemson, Team 5-4, Hunter Fall 2021 Member of Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 41
All Time: 818
