Garmin fenix 6X Sapphire Display Replacement
  1. Garmin fenix 6X Sapphire Display Replacement, Display: step 1, image 1 of 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
    Ask FixBot
  2. Garmin fenix 6X Sapphire Display Replacement: step 2, image 1 of 2 Garmin fenix 6X Sapphire Display Replacement: step 2, image 2 of 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
    Ask FixBot
8 other people completed this guide.
matthew long
665 Reputation
5 Guides authored
Clemson, Team 1-5, Hunter Spring 2022 Member of Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Members
17 Guides authored
2 Guide Comments
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - Reply Share
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - Reply Share
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 230
All Time: 14,493
