Introduction
Go to step 1 ↓The memory card is an important piece to your Garmin eTrex 22x GPS device, as it allows you to use pre-loaded maps on your device, and can also be used to give your device more storage. This guide will assist you through the steps required to replace your memory card.
Turn the handle counter-clockwise.
Lift the cover off of the battery housing.
Remove the batteries from the housing.
