Garmin Vivoactive Motherboard Replacement
Views: 15K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
90
All Time:
15,267
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The motherboard is one of the most important components of any electronic device. Damage to the motherboard could result for a variety of reasons. Replacing it may be the best option to get your Vivoactive back to running like new.
The Garmin team did a fantastic job backing a lot of punch into this tiny board, some of the most notable components are:
  • GPS and GLONASS antenna
  • Bluetooth antenna
  • Heartbeat Sensor antenna
  • Non-Volatile Flash Memory and RAM
If you're having problems with any of these components, you should consider following this replacement guide for a solution.
Parts
Tools
    1. Garmin Vivoactive Motherboard Replacement, Wristband: step 1, image 1 of 1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      Ask FixBot
    2. Garmin Vivoactive Motherboard Replacement: step 2, image 1 of 2 Garmin Vivoactive Motherboard Replacement: step 2, image 2 of 2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      Ask FixBot
    1. Garmin Vivoactive Motherboard Replacement, Display Unit: step 3, image 1 of 1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      Ask FixBot
    2. Garmin Vivoactive Motherboard Replacement: step 4, image 1 of 2 Garmin Vivoactive Motherboard Replacement: step 4, image 2 of 2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      Ask FixBot
    3. Garmin Vivoactive Motherboard Replacement: step 5, image 1 of 1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      Ask FixBot
    4. Garmin Vivoactive Motherboard Replacement: step 6, image 1 of 1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      Ask FixBot
    5. Garmin Vivoactive Motherboard Replacement: step 7, image 1 of 1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      Ask FixBot
    6. Garmin Vivoactive Motherboard Replacement: step 8, image 1 of 1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      Ask FixBot
    1. Garmin Vivoactive Motherboard Replacement, Battery: step 9, image 1 of 2 Garmin Vivoactive Motherboard Replacement, Battery: step 9, image 2 of 2
      • Follow previous guides until you've exposed the battery as shown.
      • Begin by removing the battery connector tab.
      • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
      Ask FixBot
    2. Garmin Vivoactive Motherboard Replacement: step 10, image 1 of 2 Garmin Vivoactive Motherboard Replacement: step 10, image 2 of 2
      • Use a plastic opening pick to gently pry out the battery as shown.
      • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
      Ask FixBot
    3. Garmin Vivoactive Motherboard Replacement: step 11, image 1 of 3 Garmin Vivoactive Motherboard Replacement: step 11, image 2 of 3 Garmin Vivoactive Motherboard Replacement: step 11, image 3 of 3
      • With the battery loose from the case, rotate it to expose the attached tab
      • Gently pry up the attached tab with a fingernail.
      • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
      Ask FixBot
    1. Garmin Vivoactive Motherboard Replacement, Motherboard: step 12, image 1 of 2 Garmin Vivoactive Motherboard Replacement, Motherboard: step 12, image 2 of 2
      • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
      • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
      Ask FixBot
    2. Garmin Vivoactive Motherboard Replacement: step 13, image 1 of 2 Garmin Vivoactive Motherboard Replacement: step 13, image 2 of 2
      • Use the spudger to pry up the board from the case.
      • Insert the spudger a minimum distance beneath the board as there are components below.
      • Wiggle the exposed side of the board from each end until it comes free.
      • Use proper electrostatic discharge safety when removing and handling the board.
      Ask FixBot
    3. Garmin Vivoactive Motherboard Replacement: step 14, image 1 of 2 Garmin Vivoactive Motherboard Replacement: step 14, image 2 of 2
      • Remove the GPS antenna by sliding it away from the board.
      • Keep track of the antenna and add it to the new board upon replacement.
      Ask FixBot
2 other people completed this guide.
Tessa Gunnin
466 Reputation
2 Guides authored
Cal Poly, Team 1-21, Maness Fall 2015 Member of Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 Members
60 Guides authored
2 Guide Comments
Any tips on where to buy a motherboard?
Breener - Reply Share
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
Yong-Ming Yu - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 90
All Time: 15,267
