Garmin Vívoactive 4 Battery Replacement
  1. Garmin Vívoactive 4 Battery Replacement, Watch Band: step 1, image 1 of 1
    • Flip the watch on its back to reveal the watch band connection pins.
    Ask FixBot
  2. Garmin Vívoactive 4 Battery Replacement, Remove Bands: step 2, image 1 of 3 Garmin Vívoactive 4 Battery Replacement, Remove Bands: step 2, image 2 of 3 Garmin Vívoactive 4 Battery Replacement, Remove Bands: step 2, image 3 of 3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
    Ask FixBot
  3. Garmin Vívoactive 4 Battery Replacement: step 3, image 1 of 1
    • With both straps removed, a new replacement watch band may be inserted.
    Ask FixBot
  4. Garmin Vívoactive 4 Battery Replacement, Screen: step 4, image 1 of 1
    • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
    • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
    Ask FixBot
  5. Garmin Vívoactive 4 Battery Replacement: step 5, image 1 of 2 Garmin Vívoactive 4 Battery Replacement: step 5, image 2 of 2
    • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
    • Pry the screen off the device.
    • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
    • Work quickly so the adhesive doesn’t cool too much.
    Ask FixBot
  6. Garmin Vívoactive 4 Battery Replacement: step 6, image 1 of 3 Garmin Vívoactive 4 Battery Replacement: step 6, image 2 of 3 Garmin Vívoactive 4 Battery Replacement: step 6, image 3 of 3
    • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
    Ask FixBot
  7. Garmin Vívoactive 4 Battery Replacement: step 7, image 1 of 1
    • Remove the screen.
    Ask FixBot
  8. Garmin Vívoactive 4 Battery Replacement, Motherboard: step 8, image 1 of 1
    • Carefully peel off the ribbon tape that is holding down the motherboard.
    Ask FixBot
  9. Garmin Vívoactive 4 Battery Replacement: step 9, image 1 of 1
    • Place the tip of your spudger under the edge of the connector, and pry the connector straight up from its socket to disconnect the battery from the motherboard.
    • Do this carefully to avoid ripping the cable.
    Ask FixBot
  10. Garmin Vívoactive 4 Battery Replacement: step 10, image 1 of 3 Garmin Vívoactive 4 Battery Replacement: step 10, image 2 of 3 Garmin Vívoactive 4 Battery Replacement: step 10, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the 3.2 mm screw on the motherboard.
    • Use a Phillips #00 screwdriver to remove the 4.8 mm screw on the motherboard.
    Ask FixBot
  11. Garmin Vívoactive 4 Battery Replacement: step 11, image 1 of 3 Garmin Vívoactive 4 Battery Replacement: step 11, image 2 of 3 Garmin Vívoactive 4 Battery Replacement: step 11, image 3 of 3
    • Pull the battery cable up to dislodge the motherboard.
    • Gently remove the motherboard from the socket.
    • The motherboard may get caught under the housing due to the clips on the edge.
    Ask FixBot
  12. Garmin Vívoactive 4 Battery Replacement, Battery: step 12, image 1 of 2 Garmin Vívoactive 4 Battery Replacement, Battery: step 12, image 2 of 2
    • Use the pointed tip of a spudger to carefully push on each side of the battery connector to disconnect the battery from the motherboard.
    Ask FixBot
  13. Garmin Vívoactive 4 Battery Replacement: step 13, image 1 of 3 Garmin Vívoactive 4 Battery Replacement: step 13, image 2 of 3 Garmin Vívoactive 4 Battery Replacement: step 13, image 3 of 3
    • Use a spudger to pry the battery from the case.
    • Be careful not to damage any surrounding components.
    • There is an adhesive holding the battery down. Use an iOpener if it is too difficult to remove the battery with the spudger alone.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
9 other people completed this guide.
Bryan Chavez
380 Reputation
4 Guides authored
UMass Dartmouth, Team 1-3, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-3, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G3
4 Members
16 Guides authored
8 Guide Comments
There's a warning about the battery connectors in this reddit thread https://www.reddit.com/r/GarminWatches/c...
Look for a comment by Willthedoctor from Nov 2023
Dereko - Reply Share
Hello, when assembling back the watch, how to ensure tightness, do you add glue or a cement ? thanks
Xavier Dlc - Reply Share
Thank you so much Bryan! You helped me fix my Garmin!
Jeremy Cumplido - Reply Share
my garmin doesn't work after changing the battery, it can't even connect to the app, it looks like the BT is dead
I will charge the new battery /361-00086-00/ to a maximum of 30 percent, WTF
any ideas??? pls
Lubo - Reply Share
Did ifixit previously sell a VA4 battery themselves? This page now just links to an external site Joesge.com. They sell a 178mAh battery, labelled as Grade A Cosmetic Condition. Currently sold out, doesn’t indicate wether it will be restocked.
Deacon - Reply Share
Past 24 Hours: 39
Past 7 Days: 300
Past 30 Days: 1,518
All Time: 49,149
