Garmin StreetPilot c320 Rear Case Assembly Replacement
    1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: step 1, image 1 of 2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: step 1, image 2 of 2
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      Ask FixBot
    2. Garmin StreetPilot c320 Rear Case Assembly Replacement: step 2, image 1 of 2 Garmin StreetPilot c320 Rear Case Assembly Replacement: step 2, image 2 of 2
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      Ask FixBot
    3. Garmin StreetPilot c320 Rear Case Assembly Replacement: step 3, image 1 of 1
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      Ask FixBot
Andrew Burman
1 Reputation
1 Guide authored
Cal Poly, Team 11-19, Maness Winter 2012 Member of Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,688
