Garmin StreetPilot c320 LCD Screen Replacement
    1. Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: step 1, image 1 of 2 Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: step 1, image 2 of 2
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      Ask FixBot
    2. Garmin StreetPilot c320 LCD Screen Replacement: step 2, image 1 of 2 Garmin StreetPilot c320 LCD Screen Replacement: step 2, image 2 of 2
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      Ask FixBot
    3. Garmin StreetPilot c320 LCD Screen Replacement: step 3, image 1 of 1
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      Ask FixBot
    1. Garmin StreetPilot c320 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
      • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
      Ask FixBot
    2. Garmin StreetPilot c320 LCD Screen Replacement: step 5, image 1 of 1
      • Slightly lift the motherboard upwards to reveal the LCD assembly.
      • Do not remove the motherboard yet, as it is stil attached to the LCD.
      Ask FixBot
    3. Garmin StreetPilot c320 LCD Screen Replacement: step 6, image 1 of 1
      • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
      • Disconnect the right connector using the edge of a plastic opening tool.
      Ask FixBot
Arturo Barajas
11 Reputation
3 Guides authored
Cal Poly, Team 11-19, Maness Winter 2012 Member of Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Members
48 Guides authored
1 Guide Comment
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
Ricky Graham - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,877
