Garmin Rino 700 Battery Replacement
  1. Garmin Rino 700 Battery Replacement, Battery Disconnect: step 1, image 1 of 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
    Ask FixBot
  2. Garmin Rino 700 Battery Replacement: step 2, image 1 of 2 Garmin Rino 700 Battery Replacement: step 2, image 2 of 2
    • Remove the battery cover and set it to the side.
    Ask FixBot
  3. Garmin Rino 700 Battery Replacement: step 3, image 1 of 2 Garmin Rino 700 Battery Replacement: step 3, image 2 of 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
    Ask FixBot
  4. Garmin Rino 700 Battery Replacement, Battery: step 4, image 1 of 3 Garmin Rino 700 Battery Replacement, Battery: step 4, image 2 of 3 Garmin Rino 700 Battery Replacement, Battery: step 4, image 3 of 3
    • Using a Phillips #000 screwdriver, remove the two 4.8 mm screws holding the battery bracket in place.
    • Using a plastic opening tool, remove the battery from the back case of the device.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Abigail Dugan
512 Reputation
5 Guides authored
Clemson, Team 5-5, Hunter Fall 2021 Member of Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 59
All Time: 2,356
