Garmin Nuvi 56LMT Display Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
69
All Time:
606
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the display screen on your Garmin Nuvi 56lmt.
Tools
    1. Garmin Nuvi 56LMT Display Screen Replacement, Display Screen: step 1, image 1 of 1
      • Power down the device before proceeding.
      • Locate the four 11.0 mm Torx screws and remove them with the T5 Torx screwdriver.
      Ask FixBot
    2. Garmin Nuvi 56LMT Display Screen Replacement: step 2, image 1 of 1
      • Find the crevice where the front and back of the device meet.
      Ask FixBot
    3. Garmin Nuvi 56LMT Display Screen Replacement: step 3, image 1 of 1
      • Run the plastic opening tool around the border of the device until it can be easily pried open by hand.
      • Be careful to not damage the ribbon cable by completely pulling the back from the front.
      Ask FixBot
    4. Garmin Nuvi 56LMT Display Screen Replacement: step 4, image 1 of 1
      • Carefully use the spudger to flip open the ZIF connector.
      Ask FixBot
    5. Garmin Nuvi 56LMT Display Screen Replacement: step 5, image 1 of 2 Garmin Nuvi 56LMT Display Screen Replacement: step 5, image 2 of 2
      • With your fingers hold back each of the clips located around the border of the screens back.
      • Pull screen up and slide out in the opposite direction of the ribbon to avoid snapping the fixed clips.
      Ask FixBot
Dustin Saxon
228 Reputation
2 Guides authored
USF Tampa, Team S3-G5, Nance Fall 2017 Member of USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 69
All Time: 606
