Garmin Nuvi 42LM Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
75
All Time:
886
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
You will be removing several screws to get to the screen. Eventually, you will pop out the screen to replace it.
Tools
    1. Garmin Nuvi 42LM Screen Replacement, Back Cover: step 1, image 1 of 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: step 1, image 2 of 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: step 1, image 3 of 3
      • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
      Ask FixBot
    2. Garmin Nuvi 42LM Screen Replacement: step 2, image 1 of 3 Garmin Nuvi 42LM Screen Replacement: step 2, image 2 of 3 Garmin Nuvi 42LM Screen Replacement: step 2, image 3 of 3
      • Pry the GPS open using a plastic opening tool.
      • When prying open the device, use caution to avoid damaging the motherboard.
      Ask FixBot
    1. Garmin Nuvi 42LM Screen Replacement, Motherboard: step 3, image 1 of 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: step 3, image 2 of 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: step 3, image 3 of 3
      • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
      • There are two screws - one in the back and one in the front.
      Ask FixBot
    2. Garmin Nuvi 42LM Screen Replacement: step 4, image 1 of 1
      • Move the motherboard from from its designated location on the GPS.
      • Do not pull on red, green, and black cables when repositioning the motherboard.
      Ask FixBot
    3. Garmin Nuvi 42LM Screen Replacement: step 5, image 1 of 2 Garmin Nuvi 42LM Screen Replacement: step 5, image 2 of 2
      • Gently unplug the red, green, and black bundled cable to remove the battery.
      Ask FixBot
    4. Garmin Nuvi 42LM Screen Replacement: step 6, image 1 of 2 Garmin Nuvi 42LM Screen Replacement: step 6, image 2 of 2
      • Use blue plastic opening tool to carefully pry the battery from the GPS.
      • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
      Ask FixBot
    5. Garmin Nuvi 42LM Screen Replacement: step 7, image 1 of 1
      • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
      • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
      • Check out this awesome guide on how to solder and desolder connections.
      Ask FixBot
    1. Garmin Nuvi 42LM Screen Replacement, Screen: step 8, image 1 of 2 Garmin Nuvi 42LM Screen Replacement, Screen: step 8, image 2 of 2
      • Push out the screen by pulling back the black clips.
      • The screen is attached to the motherboard and needs to be replaced with it.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 75
All Time: 886
