Garmin Nuvi 42LM Motherboard Replacement
  1. Garmin Nuvi 42LM Motherboard Replacement, Back Cover: step 1, image 1 of 3 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: step 1, image 2 of 3 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Motherboard Replacement: step 2, image 1 of 3 Garmin Nuvi 42LM Motherboard Replacement: step 2, image 2 of 3 Garmin Nuvi 42LM Motherboard Replacement: step 2, image 3 of 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Motherboard Replacement, Motherboard: step 3, image 1 of 3 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: step 3, image 2 of 3 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Motherboard Replacement: step 4, image 1 of 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Motherboard Replacement: step 5, image 1 of 2 Garmin Nuvi 42LM Motherboard Replacement: step 5, image 2 of 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Motherboard Replacement: step 6, image 1 of 2 Garmin Nuvi 42LM Motherboard Replacement: step 6, image 2 of 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Motherboard Replacement: step 7, image 1 of 1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 571
