Garmin Nuvi 42LM Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
91
All Time:
1,964
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Before replacing the battery, visit this device's troubleshooting page to determine whether you need to replace the battery. Follow the steps in this guide if you need to replace the battery.
Tools
    1. Garmin Nuvi 42LM Battery Replacement, Battery: step 1, image 1 of 3 Garmin Nuvi 42LM Battery Replacement, Battery: step 1, image 2 of 3 Garmin Nuvi 42LM Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
      Ask FixBot
    2. Garmin Nuvi 42LM Battery Replacement: step 2, image 1 of 3 Garmin Nuvi 42LM Battery Replacement: step 2, image 2 of 3 Garmin Nuvi 42LM Battery Replacement: step 2, image 3 of 3
      • Pry the GPS open using a plastic opening tool.
      • When prying open the device, use caution to avoid damaging the motherboard.
      Ask FixBot
    3. Garmin Nuvi 42LM Battery Replacement: step 3, image 1 of 3 Garmin Nuvi 42LM Battery Replacement: step 3, image 2 of 3 Garmin Nuvi 42LM Battery Replacement: step 3, image 3 of 3
      • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
      • There are two screws - one in the back and one in the front.
      Ask FixBot
    4. Garmin Nuvi 42LM Battery Replacement: step 4, image 1 of 1
      • Move the motherboard from from its designated location on the GPS.
      • Do not pull on red, green, and black cables when repositioning the motherboard.
      Ask FixBot
    5. Garmin Nuvi 42LM Battery Replacement: step 5, image 1 of 2 Garmin Nuvi 42LM Battery Replacement: step 5, image 2 of 2
      • Gently unplug the red, green, and black bundled cable to remove the battery.
      Ask FixBot
    6. Garmin Nuvi 42LM Battery Replacement: step 6, image 1 of 2 Garmin Nuvi 42LM Battery Replacement: step 6, image 2 of 2
      • Use blue plastic opening tool to carefully pry the battery from the GPS.
      • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
      Ask FixBot
1 Guide Comment
on my Nuvi 55-diconnected ribbon cable by accident. When I reconnect I get a white screen. How to get the terminals to line up correctly?
Mike - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 91
All Time: 1,964
