Garmin Nuvi 265WT Battery Replacement
  1. Garmin Nuvi 265WT Battery Replacement, LCD Display: step 1, image 1 of 3 Garmin Nuvi 265WT Battery Replacement, LCD Display: step 1, image 2 of 3 Garmin Nuvi 265WT Battery Replacement, LCD Display: step 1, image 3 of 3
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
    Ask FixBot
  2. Garmin Nuvi 265WT Battery Replacement: step 2, image 1 of 3 Garmin Nuvi 265WT Battery Replacement: step 2, image 2 of 3 Garmin Nuvi 265WT Battery Replacement: step 2, image 3 of 3
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
    Ask FixBot
  3. Garmin Nuvi 265WT Battery Replacement: step 3, image 1 of 3 Garmin Nuvi 265WT Battery Replacement: step 3, image 2 of 3 Garmin Nuvi 265WT Battery Replacement: step 3, image 3 of 3
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
    Ask FixBot
  4. Garmin Nuvi 265WT Battery Replacement: step 4, image 1 of 3 Garmin Nuvi 265WT Battery Replacement: step 4, image 2 of 3 Garmin Nuvi 265WT Battery Replacement: step 4, image 3 of 3
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
    Ask FixBot
  5. Garmin Nuvi 265WT Battery Replacement: step 5, image 1 of 3 Garmin Nuvi 265WT Battery Replacement: step 5, image 2 of 3 Garmin Nuvi 265WT Battery Replacement: step 5, image 3 of 3
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
    Ask FixBot
  6. Garmin Nuvi 265WT Battery Replacement: step 6, image 1 of 3 Garmin Nuvi 265WT Battery Replacement: step 6, image 2 of 3 Garmin Nuvi 265WT Battery Replacement: step 6, image 3 of 3
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
    Ask FixBot
    • Unscrew all four screws using the #0 Phillips screw head. Save the screws
    Ask FixBot
  7. Garmin Nuvi 265WT Battery Replacement: step 8, image 1 of 1
    • Lift up the Mother Board
    Ask FixBot
  8. Garmin Nuvi 265WT Battery Replacement: step 9, image 1 of 1
    • Slowly unclip by pulling the green, and red wire.
    Ask FixBot
  9. Garmin Nuvi 265WT Battery Replacement: step 10, image 1 of 1
    • Use the nylon spudger to remove the battery.
    • The metal spudger should be used whenever possible, especially around batteries and other sensitive internal components.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Be sure to only follow steps 1 thru 4 in the other guide listed. Clasp will be black.
Patricia Gonzalez
337 Reputation
3 Guides authored
Texas Tech, Team 6-4, Bennett Fall 2016 Member of Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,593
