Garmin Nuvi 2599 Motherboard Replacement
  1. Garmin Nuvi 2599 Motherboard Replacement, Display: step 1, image 1 of 2 Garmin Nuvi 2599 Motherboard Replacement, Display: step 1, image 2 of 2
    • Use a T4 Torx screwdriver to remove the four 5.8 mm screws from the back of the device.
    Ask FixBot
  2. Garmin Nuvi 2599 Motherboard Replacement: step 2, image 1 of 2 Garmin Nuvi 2599 Motherboard Replacement: step 2, image 2 of 2
    • Insert an opening pick into the seam between the top and bottom case and slide it around the edge of the device to release the clips holding them together.
    • Insert an opening tool into the seam between the top and bottom casing, and gently pry them apart.
    • Avoid pulling them apart, as there are cables connecting the top and bottom case.
    Ask FixBot
  3. Garmin Nuvi 2599 Motherboard Replacement: step 3, image 1 of 2 Garmin Nuvi 2599 Motherboard Replacement: step 3, image 2 of 2
    • Use an opening tool or a clean fingernail to flip up the locking flap on the display cable—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the ribbon cable out of its socket.
    • Remove the display assembly.
    Ask FixBot
  4. Garmin Nuvi 2599 Motherboard Replacement, Motherboard: step 4, image 1 of 2 Garmin Nuvi 2599 Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Use the angled tweezers to gently disconnect the battery connector from the socket on the motherboard.
    Ask FixBot
  5. Garmin Nuvi 2599 Motherboard Replacement: step 5, image 1 of 1
    • Use a T4 Torx bit screwdriver to remove the four 5.8 mm screws from the motherboard.
    • Remove the motherboard.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bax Edwards
757 Reputation
5 Guides authored
Texas Tech, Team 41-8, Allen Fall 2025 Member of Texas Tech, Team 41-8, Allen Fall 2025
TTU-ALLEN-F25S41G8
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 51
