Garmin Nuvi 2599 Display Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
47
All Time:
261
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide provides instructions for how to replace the display in your Garmin Nuvi 2599 GPS.
Tools
    1. Garmin Nuvi 2599 Display Replacement, Display: step 1, image 1 of 2 Garmin Nuvi 2599 Display Replacement, Display: step 1, image 2 of 2
      • Use a T4 Torx screwdriver to remove the four 5.8 mm screws from the back of the device.
      Ask FixBot
    2. Garmin Nuvi 2599 Display Replacement: step 2, image 1 of 2 Garmin Nuvi 2599 Display Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the top and bottom case and slide it around the edge of the device to release the clips holding them together.
      • Insert an opening tool into the seam between the top and bottom casing, and gently pry them apart.
      • Avoid pulling them apart, as there are cables connecting the top and bottom case.
      Ask FixBot
    3. Garmin Nuvi 2599 Display Replacement: step 3, image 1 of 2 Garmin Nuvi 2599 Display Replacement: step 3, image 2 of 2
      • Use an opening tool or a clean fingernail to flip up the locking flap on the display cable—this is the unlocked position.
      • Use tweezers or your fingers to gently pull the ribbon cable out of its socket.
      • Remove the display assembly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bax Edwards
757 Reputation
5 Guides authored
Texas Tech, Team 41-8, Allen Fall 2025 Member of Texas Tech, Team 41-8, Allen Fall 2025
TTU-ALLEN-F25S41G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 47
All Time: 261
