Introduction
Problems with charging the battery? The USB port bent out of shape and unable to plug into the charging cable? It might be time to replace the USB Port.
Place the device on the workspace so the screen is facing downward.
Remove the t5 screwdriver head and replace it with the j000 screwdriver head from the toolkit.
Disconnect all the wires from the circuit board.
Using the j000 screwdriver, remove all four 5.1mm screws from the circuit board and place them safely on the table (separate from the case ones)
Gently pry circuit board from the bottom shell and place it gently on the work surface
Grab the replacement USB port with the metal tweezers from the toolkit.
Grab the solder and place it on the location of the previous USB port.
Place the replacement port and place it over the solder.
While holding the USB port in place with the tweezers, use the soldering iron to heat up the solder underneath the port.
Let the port cool for an hour.
3 other people completed this guide.
14 Guide Comments
where to buy the replacement part?
The link to the Garmin Nuvi 2595lmt Replacement Port show 3 legs and in the picture above there hare 5 legs
The part for sale on eBay and the one in the pictures are not the same connector. If you want to read more about this problem try this link:
The link points to a different kind of connector, while it's not 3 pin (the two additional pins are a bit in behind the row of 3 pins) it's wrong and won't work.
However I did not need a new connector, just solder back the current connector and it now works fine (until next time).
One thing that isn't to clear is that the battery and speaker wires are pulled straight up from the board, not sideways in the connector as I first thought.
